Old 09-21-2014, 02:27 PM   #183 (permalink)
XYZ
Originally Posted by Baltothewolf View Post
XYZ, you think I was jerking you around?
You are understandably frustrated in your attempts to diagnose the problem. If you slow down and check each step thoroughly you might find something you overlooked. Everyone here is eagerly trying you help you - but we all get caught up in hasty responses and misunderstandings.
I don't hold grudges, so let's continue with trying to solve your problem.
Who did the alteration of the wiring with the wire nuts? Was it you or the previous owner?
I'm not familiar with your particular car's design, but usually a cooling fan is activated by sending 12v to the fan motor, and the other leg is routed to ground. As such, there is no polarity to be reversed. Also, electrical connectors are unidirectional, meaning they only fit together one way (unless someone altered the original wiring).
Did you happen to install the fan itself backwards? I'm not being facetious in asking. I don't know if that is physically possible, but it is a plausible possibility. Regardless, if the fan is running it's still providing some cooling in blowing air through the radiator, as opposed to the fan not running at all.
