Old 09-21-2014, 06:56 PM   #1136 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
Well, that was also carefully verifying the value of each part in the schematic though. The software is ready to start testing/debugging on the bench without the motor.
The parts verify would be more 'eyes go fuzzy' work if I were to do it.
I can't remember if I posted this - a plan for testing the AC controller:
- a netgain 9 inch DC motor with an existing 1000A 400V controller
- my 30 HP AC motor with Paul's AC controller
- coupled with the largest joy coupler that I can get to fit
- set up the AC controller for regen
- both controllers run from same battery pack - 400V
- battery charger set up to 'top up' battery pack as energy is removed
- run up the AC motor with the AC controller
- turn up the DC controller until the rpm begins to increase (AC current drops off)
- creep down the speed of the AC controller and begin regen
- increase DC torque output as required to stay around 1750 rpm
- increase regen on AC controller
- repeat until maximum regen or maximum current on DC motor
- log each step and max current when limit is reached
The second test will have the AC motor shaft coupler bolted to a solid frame, and the AC controller will ramp up quickly (maybe 10v/ms) to about 3X rated slip (150 rpm), which should get me 4X rated current, or perhaps a bit more, but at a low voltage. My clamp-on meter is not real accurate, but this should determine if the LEM Hass current sensors are in the right ball park
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (09-21-2014)
