My cobalt has the battery in the trunk from the factory, I'll look and see if GM put any fuse in it.
A quick search found a 50 amp fuse in negative cable.
EDIT: Went out and looked at it, I'm not sure what the 50a fuse protects, the, negative cable goes to battery mount that I assume is grounded, feels pretty solid, the 50a fuse is right next to it but didn't try to figure out the wiring. I don't think 50a is enough to run the starter. Maybe that's the accessories only.
