Old 09-22-2014, 12:05 PM   #1 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Help on running a second deep cell battery
The mod that drives me crazy but I need it for my turbo compound system
(for racing) is my Tilton 40-527 external oil pump. It doesn't help at all with FE and takes away FE from the extra load on the alternator. So I decided to add a secondary deep cell battery to run it most of the time and charge this battery at home and work. I pulled around 200lbs of weight off the car so the extra weight from the deep cell won't be to bad.
This is a post from another thread, What's your least efficient mod?
I need some help to build a system (secondary deep cell battery )that can be charge from my alternator sometimes in case of a "long distance commute", but most of the time "short commutes" it will be charged at work and home.
Electronics are my weak point so some advice would be great!!!
Pressure Gradient Force
The Positive Side of the Number Line
