Do you know if Paul's controller is amenable to mixing battery types, and differing voltage inputs?
Paul's controller is battery agnostic. If the battery pack supplies current, Paul's controller will use it. There is a voltage range (that I can't locate right now). To drive 650V I believe a few capacitors had to be changed out? Not sure on the low end - about 48V, perhaps?
I think you would need to be careful mixing battery chemistries for different reasons. The charge curves are, I believe, different. So the charger used for a NiMH pack would expect the charge curve to rise at different points than a LiFePO4 cell. I expect the charge to terminate using different rules as well.
That assumes that the packs are in parallel. If they are in series, I think you would need separate chargers as well ... but that's a guess.
In series, you would be limited to the max current of the lowest-rated pack and the amp-hours of the lowest capacity pack.
