Originally Posted by Baltothewolf
We insight owners also use the 98-02 accord/Odyssey EGRS as they work just fine, and is only 64.99 on eBay vs the 270$ for a new one specifically for the insight. I'm glad you got that solved, I have the EGR insufficient flow CEL as well, but I'm just gonna opt for a new EGR.
Great tip, that is a MUCH better price than the parts store.
the hx and accord unit are identical except for the plug position so I'll give it a try if worse comes to worse
I'm not sure if the problem is solved, but I do know for sure know it could only be the valve itself if the light comes back on.
Don't suppose you know what pins on the egr valve I could use to make the valve extend using a 12v power source? That may be a project for the bad valve I suppose
Oh also would "porting" the exit opening on the egr base to be the same size as the opening on the intake manifold improve the air flow?
