Old 09-23-2014, 11:50 PM   #61 (permalink)
fjasper
Bookworm
Sylvio 2 - '04 Audi allroad quattro Biturbo 6-spd
90 day: 25.09 mpg (US)
Atlas - '04 Audi allroad 2.7T 6MT
Redline MTL 75w80 gear oil will probably work fine. It's a little lighter, and works nicely in cold weather, but it still has good friction properties to keep the synchros happy so shifts are smooth. I had good luck with it in an older Audi and an '89 Tercel 5-speed.
Seems like an advantage of using coolant to influence trans oil temp is that it should also function as a transmission cooler in hot weather.
