BTW Doax ... what is max sidewall for your tires? And do you run 60 in all?
I was thinking of bumping the fronts up to 55 and leaving the rears @ 50 since I have so little weight back there now ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Reason: cant spelle
