Such a pain. Check engine light came back on for flow so I went back through the intake passage and it was completely clogged under the passageway on top of the manifold. So the intake manifold to combustion chamber was completely clogged
I used a small drill bit by hand to try and remove as much debris as possible without pushing it all into the combustion chamber. I then used my vacuum gun to try and suck all that debris up and out.
I may actually have to remove the intake manifold if this last cleaning session didn't work. :/
Also the odyssey egr valve looks more like the insight egr valve according to a few part stores
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
