Old 09-24-2014, 05:16 AM   #62 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
What about using a length of copper tube wrapped around the exhaust ?
Then you get free heat back and you can direct it into the engine and trans.
Of course you have to thermostat it for when you hit peak temp on longer trips.
This is only suitable for older vehicle without a cat' obviously.
Also it would call for a a oil to water heat exchanger somewhere wich would be the real killer engineering wise ...
