Old 09-24-2014, 05:20 AM   #143 (permalink)
paulgato
Black Beast - '02 VW Goff Estate S
Originally Posted by oldtamiyaphile View Post
I don't think there's a thread on a diesel kill switch, as the usual method of ignition and fuel pump won't work.
However, I wouldn't go fitting a kill switch to a TDI anyway if you want the turbo to survive. For the occasional long traffic light (after a long DFCO) I just use the ignition switch. By comparison, in a petrol, you might be killing the ignition ten times per mile hence the need for a convenient dedicated switch.
Thanks for advice, but a) what is 'DFCO', and b) what is the issue with the turbo? Can I not simply kill the fuel injector pump? What is the difference between that and keying off and on again? (...other than wear and tear on the ignition switch of course.)
I tend to switch engine off at long red traffic lights, and also on long, straight shallow descents where I don't want to use engine braking.
