Originally Posted by darcane
So, capabilities of a mid-size truck with fuel-economy worse than a full-size?
You just reiterated the whole point of this thread...
No, Pale was pointing out how people were ridiculously misrepresenting the capabilities of the Ridgeline. There are comments saying that it's less useful than an El Camino.
The El Camino has a smaller bed capacity, a payload rating of 1000 lbs compared with the Ridgeline's 1500 lbs, and has fuel economy that is laughable, even when compared with the Ridgeline's unimpressive numbers. The car is a turd, and there is a reason that the Ridgeline is selling in the year 2014, and the El Camino is not.
There are also comments saying that the Ridgeline is not tow rated. Actually, it has a tow rating of 5,000 lbs; enough to tow a typical sedan on a trailer.
I've seen a Ridgeline hauling two 4-wheelers in the bed along with various gear.
Yes, the truck gets pathetic fuel economy given it's limitations, but it isn't worse than an El Camino, or incapable of towing.
