Old 09-24-2014, 09:55 PM   #16 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
The shuddering goes away when the engine is warm. This morning I ran the block heater before work for two hours and the valve cover was warm to touch, and presumably the flywheel as well. No shudder.
I will do the clutch and flywheel eventually. The rear main seal is leaking anyway. It's not bad enough to worry about at this point.
