Old 09-24-2014, 10:06 PM   #72 (permalink)
pjbgravely
Horse with no name - '00 Ford Mustang Base
Team Mustang
90 day: 20.53 mpg (US)
Orange peel - '00 Ford Focus SE
90 day: 26.83 mpg (US)
That is strange. In the old days automatics had a lower ration so using an automatic gearing resulted in higher engine speeds.
I like your idea. I was designing a belly pan to achieve the same thing by letting the exhaust pipes heat the transmission in a rear wheel drive. I have yet to complete it but I think it would have needed a louvered lower grill block to allow the engine to actually heat up before 10 miles.
Personally I would use an electric block heater to preheat the engine and trans-axle if electricity is cheap where you live. Finding a way to heat the trans-axle with coolant is the real challenge.
