Old 09-25-2014, 11:05 AM   #121 (permalink)
u.steinlechner
Hello,
the wind tunel is a very expensive method of measurement.
You can improve the quaity of your aerodynamic by wool threads on the surface.
For fine modifications, I made testdrives, then I changed the shape.
Example: modification at the wheelhouse.
The wheelhouse are very sensitive, so little changes can bring a other airflow.
Before you go in to the windtunel, make sure that you can modify the car in a short time, to compare the original car with the modifications.
A flow meter diagram can also help, to estimate the results.
Measure with open and closed air intake for the heat exchange.
More photos on flickr: https://www.flickr.com/photos/ulrich-steinlechner/
Kind regards
Ulrich Steinlechner
The Following 3 Users Say Thank You to u.steinlechner For This Useful Post:
aerohead (09-25-2014), BamZipPow (09-25-2014), Cd (09-25-2014)
