Old 09-25-2014, 01:49 PM   #18 (permalink)
u.steinlechner
Flow meter
Measuring flow rates at the small volumes vehicles use is apparently problematic. Have you looked at vortex street flow meter - Google Search
Pedestrian Safety
Similat to hitting deer. Better for both the impactor and impactee if the contact is below the center of mass. Add an optional hood-mounted air bag and you have a safety feature.
I see there's no changes to the understructure. So the air is divided between the wheelwells and radiator? Are you free to discuss the added speed holes?
Hi freebeard,
i like to make sure, that we are talking about the same thing.
I used a turbine flow meter to measure the fuel consumption at constant speed at driving.
The aerodynamic measurement were made in the FKFS aero acoustics wind tunnel.
Yes, I can talk about the airflow to the heat exchanger. The air intake is in front of the wheels and inside, the bumper is a expansion airbox. The speed of the air slows down and static pressure increases.
Greetings from Germany
Ulrich
