Old 09-25-2014, 04:00 PM   #10 (permalink)
OG VX
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
OK, so need some more help with this one.
Turns out the noise was coming from the fog relay. I found it under the dash. I replaced it with another relay from a local yard. No more buzzing sound, but the fogs still don't work. Anyone know of any other fuse in the Civic fog harness?
Also, I'm now leaning more towards the fact that the voltage may be so low that the car is having problems dicphering that they are actually on.
Another thing not to rule out is that the light stalk on the column is...finicky. I can (literally) jiggle the stalk while the headlights are in the "on" position, and watch the output/voltage of the lights flicker in intensity. Additionally, when I flick the stalk to the high position, the high beams will not stay lit there unless I hold the stock back in the position where you move the stalk to flash your highs. Weird stuff. Lots of dynamics on this one. Hard to diagnose. Urg.
