Thread: Grill Block
Old 09-25-2014, 06:52 PM   #9 (permalink)
aerohead
block
The distance from the grille opening,to the face of the radiator is an important consideration.High performance cooling systems have an inlet duct which is at least as deep as the height of the radiator,and are airtight.
Without the proper depth,momentum of the incoming air stream may prevent enough divergence,necessary for the air to impact the entire face of the heat exchange media.
ChazInMT (09-26-2014)
