Old 09-25-2014, 10:18 PM   #54 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Look at what I just scored!!!
Boost activated exhaust valve. Starts to open at 9psi. Its wide open at 12psi.
I'm going to install this after the CAT. Then build a 1 1/2" dia. exhaust pipe loop around it pre-turbo that will have a Honda OEM muffler inline.
With the valve closed exhaust will have to run through the muffler. At WOT the valve will open at 9psi. and have a straight shot 3" dia. to the turbo and dump out at the quarter panel.
Pressure Gradient Force
The Positive Side of the Number Line
