09-25-2014, 11:53 PM
#10 (permalink)
Growin a stash
I highly recommend this peelable caulk. If you screw up the first time, you can rub it off with your fingers. Much better than the epoxy I used which is pretty much permanent.
Amazon.com: Dap 18354 Seal 'N Peel Removable Caulk, 10.1-Ounce: Home Improvement
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
