Old 09-26-2014, 03:45 AM   #7 (permalink)
redpoint5
90 day: 29.78 mpg (US)
I'm running supercapacitors only on my bike. 6x 400 farad capacitors wired in series. The generator is capable of maintaining 12v at idle, so I haven't had any electrical problems. If I was stuck in traffic for a long time, I might not have enough juice to run the cooling fans for very long, although I haven't run into this scenario yet. The weight is about 1 pound.
I also have a 4.2Ah LiFePo4 battery (4s, 1p) from Hobbyking. Haven't used it on my bike because I'm so happy with how it's going with just the capacitors.
I'll build a hybrid supercap/LiFePo4 battery to replace a car battery once one of them dies.
If you have any interest in the LiFePo4 battery I purchased, or the supercapacitor I'm using, visit this thread.
Originally Posted by PaulB2 View Post
Someone please explain the jargon to me. What is "4s" and "4p"? Are these cells the same size as AA's? How do you connect them together?
4s means 4 cells in series, and 4p means 4 of the 4s batteries wired in parallel, for a total of 16 individual cells.
4 of the 3.3v cells need to be wired in series to raise the battery voltage to 13.2v, which is about what a standard lead-acid battery is.
To get enough amperage to run the starter, 4 sets of the 4 series cells are wired in parallel.
The cells are larger than AA. Cells are generally soldered or spot welded together.
