Old 09-26-2014, 08:00 AM   #21 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by FordFiestaS View Post
I obviously want high MPG 's. I want to pump up my tires a bit but not ruin them. What is considered a safe PSI increase without making the tires bald in the center as a result and not setting off the tire pressure monitoring system.
Factory specs: 32 PSI
First, I am not a fan of using elevated inflation pressures, but I understand why some are.
Second, there isn't a solid answer to your question. Some folks have reported center wear on elevated inflation pressures below the max pressure - and some have reported even wear on considerably higher pressures. I think this means there is some additional factor driving the wear (in addition to the inflation pressure) .
I would urge caution. There have been reports of traction issues as well when using elevated inflation pressures.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
