Old 09-29-2014, 01:58 PM   #149 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Jakins View Post
It would be so easy to design a secondary coolant resavoir and radiator for the turbo run by an electric pump that just runs constantly. But im not a thermal engineer so I dont know how well that would work in reality.
Not sure how much flow is needed (how much heat needs to be dissipated? ) because if it's low enough, you could probably make one out of a 360 or 480mm computer radiator, a pump and wire some fans to the battery with a switch inside the car to always run it.
