Old 09-29-2014, 08:20 PM   #5 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by Rango318 View Post
I would recommend seeing if you can get a MPguino
MPGuino only connects to one injector. If that injector shuts down during DOD, you'll get a zero reading. If that connector doesn't shut down, you'll get the same reading as an OBD scanner.
You'd need to build and Arduino that connects to every injector (or each independently controlled injector bank/ pair depending on how the DOD system is set up) and sends the averaged signal to an MPGuino.
If there's a 'fuel economy' signal in the loom, MPGuino can be used to tap directly into that. Most modern European cars have that signal available at the instrument cluster, even if they didn't come with the display stock.
