Old 09-30-2014, 12:05 AM   #66 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by sqidd View Post
Are you going A2A, A2W or both?
Both are A2A.
The LP A2A is going to be a small core and run around 75%, but the length of the charge pipe back to the HP turbo should also help. Then it gets compressed again and runs through the large FMIC that is around 85%.
I'm working on building a air duct door to control flow through the LP turbo IC.
This will/should help increasing air temps for FE.
Pressure Gradient Force
The Positive Side of the Number Line
