Old 09-30-2014, 01:15 AM   #16 (permalink)
Chrysler kid
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Originally Posted by OG VX View Post
^^ Genious. Thank you. Now, how would I go about wiring in a resitor, and which type shoudl I be looking for?
All of this technology is with LED headlights is new, so there is just not enough documentation out there for common problems/fixes yet...
I can't be sure until you test the current going to the bulb and then the current to the led bulb. My theory is the draw on the switch isnt large enough and thats why it makes a buzzing noise, or it could also be from an over stressed ground wire from the switch.
I would also try a seperate ground or wire a power source separately from the factory harness.
To be honest on the camaro I took the easy way around the problem, I just wired up some 12 gauge wire to a switch to use as the primary power source instead of the factory switch. I also created my own ground location on the radiator support.
Apologies I have imited electrical knowledge on trouble shooting and I usually just find a problem and correct it by eliminating the variables
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
