Old 09-30-2014, 10:40 AM   #3 (permalink)
Andy at Focallocal
Roadtrip London2Vietnam!
thanks. i changed the filter and it fixed the issue, although i'm going to add a lift pump anyway to support things.
have a new issue now. since changing to Wvo my van is getting harder to start each morning, does anyone have any ideas what might cause this? i have a 2 tank system, starting and stopping on diesel. one thought is that i havent added a lift pump yet, which shouldnt effect the diesel tank at all - unless it means that i have damaged the main pump by overworking it. aside from that nothing has changed that i can see having any effect on the van, unless the injectors are becoming clogged!? before converting it would always start 1st key turn.
