I got ideas
Beast - '97 Mercury Mountaineer
Best Off Road tires for better FE, trucks need love too :)
Great article on tires for expedition use. Lots of knowledge that kind of goes against what most 4x4 folks say... And it would seem to be advice that justifies taller skinnier tires as true and capable off road choices. So for FE on a truck, less rolling resistance, less frontal resistance, less rotational mass, better fitment in wheel well (aerodynamics), less weight on suspension/drive-line components, etc etc.
Here's the link, and a few excerpts of interest for how a skinnier tire is just as good or better than a wider tire for a great deal of off road uses...
Expeditions West: Tire Selection for Expedition Travel
Understanding Off-highway Tire Performance:
Important note: For the sake of the following details, assume that the test vehicle is 5,000 lbs., and a narrow tire would be considered a 33x10.5 R15, and a wide tire would be considered a 33x12.5 R15, both run at 15psi for trail use.
The benefits of a narrow tire:
The Argument: A tall, narrow tire is a better choice for all off-highway surface conditions with the exception of soft sand, snow and soft mud that's depth exceeds 110% of the vehicles minimum ground clearance. Here is the explanation.
• Contact Pressure: Contact pressure is expressed as the vehicles curb weight distributed over the contact surface of four tires. The contract pressure is not equal to all four tire road surface contact points as the vehicles weight is not perfectly distributed. To ease the description, let's assume that the test vehicle weights 5,000 lbs and has a perfect weight distribution. Each of the vehicles four tires would be creating 1,250 lbs. of vertical pressure on the terrain. Let's assume for the sake of this example that the vehicles tires are 10” wide, where the load and tire pressure results in a total surface area of 30 sq. inches. The total pressure per square inch (without equating the secant) would equal 40 lbs.
Off-highway effects of contact pressure:
Deformation- On a smooth surface (like concrete), a tire gains most of its traction by adhesion. On an irregular surface like granite and boulders, a tires contact patch will deform as a result of vertical pressure. The wider the tire, the less the rubber will deform to the surface irregularity given the same vertical pressure. The greater the deformation, the greater the tires resistance to shearing forces (spinning). This is the strongest argument to using a narrower tire.
Real world example: When climbing a ledge with a jagged surface, the narrower tire will wrap the protrusions with more contact due to the increased deformation depth. The wider tire will rest on the surface of the protrusions and will have a greater chance of spinning (shearing).
![](http://www.expeditionswest.com/research/white_papers/deformation.gif)
Mechanical Keying: This is the second critical benefit of a narrower tire. As the vertical load increases, so does the compression and flexing of the tires tread and rubber to the surface protrusion. A narrower tire generates greater vertical load on the rubber and the tread, increasing tread compression in conformance to the surface irregularity. A wider tire in contact with more surface conforms less, and will shear sooner than a narrow tire.
Adhesion- On a flat surface, the adhesion rate of a narrow tire and wide tire are the same, as the wider tire makes more contact (friction area), but the narrow tire generates more pressure (vertical load force). On a highly irregular surface, the higher vertical load force of the narrow tire becomes an advantage, increasing molecular bonding between the tires rubber and trail surface. That bonding becomes so great that either the vehicle moves forward, the tire tears leaving rubber on the surface, or the trail surface breaks away.
Airing Down: This is another critical concept highlighting the advantage of a narrower tire.
Traction in soft surfaces: It is a common misconception that airing down a tire for off-road traction only makes the tire contact patch wider. That is not the case. In fact, only 20% of the increased contact comes from the width. 80% of the increased contact patch comes from the tread patch becoming longer. A tall, narrow tire allows for a very long contact patch when aired down. That, coupled with the minimal frontal resistance (area), negates much of the downside to narrow tires in flotation situations. The taller tire allows for a long contact patch and still maintains good ground clearance.
Traction on rocky trails: Another common misconception is that when airing down it is the increased amount of tire on the rock (more contact patch), that allows better traction. It is not the contact patch that creates better traction, but the tires ability to conform to the surface irregularities (deformation and mechanical keying). When an aired down tire comes in contact with a rock on the trail, the tires tread collapses under the vertical and horizontal forces, causing the tire to wrap the rock, as opposed to sitting on top of it. The wrapping effect provides greater shear resistance, and in turn better traction. (Technically: the shear load is distributed over multiple planes, not just a horizontal one).
Tire spring rate: One of the great benefits of airing down a tire is improved smoothness. Less pressure allows the carcass to flex. A taller tire has greater sidewall compression, and in turn a better ride. (expressed as compressive strength=N/mm). That is why your grandma's Cadillac had such tall tires…
Negative Effects: Nothing in the world is perfect, so there are some downsides to using a narrow tire…
Stability and high speed deflection- A narrower tire (and in turn a narrower overall vehicle track width) provides less stability on the road and on cambered trails. In addition, a taller, narrow tire's sidewalls deflect more under severe turning forces, causing the inside of the tires contact patch (midline to the vehicle) to lift (roll in) from the road, increase the chance of a high shear force skid, or loss of control.
Increased potential for trail damage- A tall narrow tire has greater contact pressure, so when crossing a sensitive area like a muddy track, the tire will want to dig down until traction is found as opposed to floating on top. Make sure to air down and apply light, smooth throttle to minimize trail damage, or just turn around and save the trail from any damage at all.
Real world examples
The Turtle Expedition who has literally traveled around the world used a 255/85 R16 (33.3 x 10) for many thousands of miles on their full size Ford. Land Rover uses narrow 7.0 R16 XCL tires in most of their Camel Trophy events. The Rain Forest Challenge and The Trophy challenge have all been won by the aggressive Simex Trekker tire (35x11.00). Tom Sheppard often uses the 7-7.5 R16 Michelin XZL and XCL for many of his expeditions. All very narrow tires in relationship to their height…
Hope this is useful to someone
~C
I'm really beginning to like eco-humor
Originally Posted by aerohead
PS you could add hamsters inside for a 'bio-hybrid' drive.
