Old 09-30-2014, 04:10 PM   #7 (permalink)
cRiPpLe_rOoStEr
You can always try something else to improve the efficiency of the air-conditioneer setup, such as adding some gel-filled pads that keep a little colder right after the compressor stops.
Originally Posted by Astro View Post
most people will think i am crazy but i really like the look of the Barina
I also like its look.
Basically it blows head gaskets like it was an Olympic event.
[/QUOTE]
I have some previous experiences with the Brazilian Chevrolet Corsa, which is basically the same car, and never had any head gasket issue. The only thing that really bothered the hell out of me was once that an ignition coil failed in a '01 Corsa sedan (which I guess was never available in Oz), leaving the engine firing only in 3 cylinders, about one month after getting the engine pressure-washed.
