Old 09-30-2014, 09:42 PM   #8 (permalink)
Astro
Dreamer
You can always try something else to improve the efficiency of the air-conditioneer setup, such as adding some gel-filled pads that keep a little colder right after the compressor stops.
If i find i am stopped long enough for the A/C pressure to drop enough for the cooling effect to reduce then i can always slip the gearbox into neutral and give the motor a little rev to get the pressure back up again.
