Old 10-02-2014, 07:00 PM   #18 (permalink)
NewMPGfrontier
GreenMachine - '98 Nissan Frontier XE 4X4
I'm still on this haven't built it yet, but took some more exact measurements to draw it out and check angles. The bed is 79.5 inches long on the outside and its 2.25 inches higher in the back, and the bottom of the third break light is 18 inches from the top of the front of the bed. Drawing all this out on paper and measuring the angle from the bottom of the third break light to the tail gate it looks like I'm at the ideal 12 degrees. I also found a sheet of .45mil EPDM roofing rubber that should be a better covering than the heavy sheet metal. The rubber might also be nice for other aero mods if I can glue it to sheet metal it would help make a durable full front air damn and side skirts maybe even wheel well covers too.
