Im not an expert on the prius.
I thought the gen 1 used cylinder cells, than the rest were the soft sided ones?
Soft sided cells need to be under compression when in use.
Gen 1 cells are hard to find, like gen 1 insight cells.
Best bet is to balance the pack at 350 ma using a few series wired mean well led power supplies.
I believe the prius itself is the best tool for servicing the battery as it gives readouts of the sticks.
750? I would of purchased it and let AAA tow it home. You could make a portable balancer using a deep cycle battery, but it still takes HOURS for it to do its thing.
