Old 10-04-2014, 01:43 PM   #31 (permalink)
Daox
I'm not sure if you have sway bars or not. Here is a picture of my non-mounted rear sway bar though:
Apparently its supposed to look more like this:
Here is the driver's side control arm mount rust. From this angle you can see one hole, I'm not sure if there is more yet.
Here is another shot of where the charcoal canister should be. The rubber hose just goes right down where the can should be as if to bypass it. Perhaps it was deleted? Any negatives from not having this? Should I be looking to pick one up somewhere? I understand what it does, I just don't know how not having one would effect things. I'd imagine you just burn the gas fumes as soon as you start up.
And, here we have the $100 set of wheels and tires. I love cheap cars. The tires are a bit old, and a little on the dry side, but they'll do just fine. They are Hifly HF201.
ID:	16009   Click image for larger version
ID:	16010   Click image for larger version
ID:	16011   Click image for larger version
ID:	16012   Click image for larger version
The Following User Says Thank You to Daox For This Useful Post:
aerohead (10-04-2014)
