Originally Posted by Old Tele man
Big difference: Aircraft engines have A/F-ratios controlled by pilot, while automobiles have A/F-ratios controlled by EPA/CARB regulations and ECM's.
No the AFR is controlled by manufacturers and you can always use ECU flashes to change it (as I explained above).
Honda will soon be returning to lean burn business again.
