I like the idea, but advise caution, basically you are using heat to partially melt the surface of the trim and that eliminates the oxidation. The difference between too much and too little is probably slim so start conservatively and work from there, with color change being your indicator. The trim needs to be in it's natural (as moulded) color or that amount of heat could cause problems with painted parts.
regards
mech
