Old 10-06-2014, 09:36 AM   #3 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
That is dependent on your situation. If you can see the red light from far off, neutral would be better as you can coast a lot farther in neutral than in gear. I'm assuming you have a manual right? Because if so, you should probably install a kill-switch, then you can coast in neutral and burn no fuel.
