Old 10-06-2014, 04:51 PM   #15 (permalink)
aerohead
why
Originally Posted by Frank View Post
Why? Something to do with ground effect? Isn't air moving around the wing the same regardless of orientation? (I think you're saying that a horizontal airfoil acts differently than a vertical one, is this correct?)
*Since the MC is narrow compared to its height,the convention is to streamline it using plan-view taper,which puts it in the domain of an 'uprighted,' 2-dimensional flow, symmetrical airfoil.
*The airfoil will essentially behave the same,whether horizontally as an 'elevator',or vertically as a 'rudder.'
*The part about having a full tail comes from empirical results from wind tunnel research.
*Truncated wing sections suffer enormous drag increase when their aft-bodies are truncated.
*And if they are truncated,they need to be 'closed' back their.One of the LSR motorcycles I just saw at Bonneville was tested at Darko Technologies wind tunnel,and it was found that the original open tail was a no-no as far as drag was concerned.
*Here's the mathematical relationship for wing truncation drag.You can arbitrarily 'build' some different sections in your calculator and see what the drag would be.
*And hint-hint,this year at Bonneville,a handful of LSR streamliners had finally adopted Walter Korff's full-tail boat tail,with clamshell doors over the parachute tubes,dating to Korff's 1965 Summer's Brothers' 'GOLDENROD'.of 555-mph design velocity.
