The easiest would be an ex sedan as it already comes with VTEC unless you are referring to canadian trim levels
You get the best economy from deleting VTEC, but your engine would also make less power than a standard non VTEC engine because it uses 1 very economical can setting and one aggressive setting. So you would be on Eco mode all the time by deleting it
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
