Originally Posted by vrmouseyd15b
hx/vx has a "shift light".
Gotcha.
Post up your pin out on the ecu, surprisingly there is very little info on the lean burn system. The only reason I know my cars is purely a shift light is because it always operates whenever the car is running, cold or hot.
Would be cool If I could pin mine and have both. And the JDM ecu didn't have any emission standards so it should be much easier to get into lean burn.
