Old 07-17-2008, 12:23 PM   #27 (permalink)
instarx
EcoModding Dilatant
Volvo - '00 Volvo V70 XC AWD SE
90 day: 27.7 mpg (US)
I agree this has gotten more serious than it deserves to be, but I think you also gave diesels a bad rap that they do not deserve. Just because there is not a 50-state diesel less than a year after it even became possible does not mean that diesels are horrible, polluting engines. Of all pollutants only NOx is not far below CA emissions requirements. I don't call that a dirty, polluting engine, I call it a clean engine with an NOx problem. Unfortunatly it doesn't matter how much you reduce all the other pollutants, you still can't exceed even one.
Originally Posted by fshagan View Post
You can not import any new European diesel car into California and register it (cars with over a certain mileage are exempt from the "must be clean" import rules).
Not quite true. You can lease a brand new E320 Bluetec diesel in California right now. Check with your local MB dealer if you don't believe me.
That "filthy, polluting, planet-destroying" comment might have been construed as ironic banter if you had not paired it with "Europeans must not care about the environment; they have been using dirty diesel engines for years...".
