Old 10-07-2014, 03:13 AM   #249 (permalink)
Xist
Is anyone else in this situation?
Overdrive (mechanics)
An overdrive (OD) is a mechanism that allows an automobile to cruise at sustained speed with reduced engine RPM, leading to better fuel economy, lower noise, and lower wear.
Okay, I had already gathered most of that, although lower wear is a nice bonus.
In the era of front-engine, rear-wheel drive layouts, the device for achieving an overdrive transmission was usually a small separate gearbox, attached to the rear of the main gearbox and controlled by its own shift lever or electrical actuation button. These were often an optional extra on some models of the same car. As popular cars became faster relative to legal limits and fuel costs became more important, particularly after the 1973 oil crisis, the use of 5-speed gearboxes became more common in mass-market cars, with the 5th gear being an overdrive, eliminating the need for a separate gearbox.
Regarding the Laycock overdrive:
The system features an oil pressure operated device attached to the back of the standard gearbox operating on the gearbox output shaft. Through a system of oil pressure, solenoids and pistons, the overdrive would drop the revs on whatever gears it was used on by 22% (.778). For instance, the overdrive system applied to a Triumph TR5 operates on 2nd, 3rd and top gear. When engaged, the overdrive would drop the revs from 3000 by 666 RPM, or from 3500 the drop would be 777 RPM to 2723 net. The advantages this reduced rpm had on fuel consumption was most often quite near 22% decrease during highway driving.
http://en.wikipedia.org/wiki/Overdrive_(mechanics)
So, the overdrive is an external taller fifth gear?
