Old 10-07-2014, 02:35 PM   #5 (permalink)
user removed
Not positive but when you crank it it gives battery power to the coil, then once it is running it goes through a resistor or it used to. If so thats your issue. Check the connections at the coil first. Could be a fuse. I'm not even sure it's done this way anymore.
regards
mech
