Old 10-07-2014, 02:24 PM   #7 (permalink)
Daox
Originally Posted by Old Mechanic View Post
Not positive but when you crank it it gives battery power to the coil, then once it is running it goes through a resistor or it used to. If so thats your issue. Check the connections at the coil first. Could be a fuse. I'm not even sure it's done this way anymore.
regards
mech
I have no idea on this. It has individual coil packs.
