Old 10-07-2014, 03:25 PM   #8 (permalink)
Daox
Originally Posted by darcane View Post
Does your immobilizer light turn off? (the green key on your dash)
Double check that all the sensors are connected, especially the crank and cam positioning sensors. These could cause similar hard-starting issues and they were disconnected when you did the head gasket.
Yeah, the green light does turn off.
I'm pretty sure all the vacuum lines are hooked up. All the sensors are plugged in. I checked that last night after it didn't start the night before.
