Originally Posted by Chrysler kid
Running nitrogen in the tires would cure both problems and tire pressure would remain constant through the temperature changes as it is not as heat sensitive as oxygen molecules
Not correct. Nitrogen is a diatomic gas like oxygen with a similar density, its characteristics are extremely similar at these sorts of temperatures.
