Thanks for the info. I like to keep my options open for when my insight needs an engine or I just want MORE POWER.
FYI, since you got the psi sensor in the vtec thingie if the screen is clogged or you have internal damage that lowered your oil psi when its time for vtec 1,2,3 to engage you will just get an vtec error and it wont engage as that will further lower your oil psi.
