Old 10-08-2014, 09:09 AM   #47 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Mazda MX6 Day 057 video 014-1 August 25, 2014
Cut the final two cables keeping me from removing the transmission. I can reconnect them if I need them!
The transmission is out, but I could not get the driver's side axle off the car. I did get it popped out of the transmission side ... not sure if I damaged anything doing that.
The adapter plate fits nicely onto the transmission.
Details on the assembly of the motor coupler to flywheel, clutch plate and pressure plate
Measure out the length of the motor and transmission versus the size of the engine bay
The video is too long and got rejected by youtube again. I wasn't paying attention. I will post a link when I get it shortened.
16:52 is OK, 17:00 is too long .. go figure!
Perhaps the max video length starts out longer and gets shorter as you use up storage space and don't generate revenue for Youtube? The first of two is down to 16:21 and I still get an error that it is too long.
So I'll split it into 3 pieces. It will be posted when I get it done.
http://youtu.be/oyTxNJh6VZ4
http://youtu.be/zSJOu_KUOTY
http://youtu.be/bKAR5NDlbwg
The last one should be finished posting by 6 pm, Sep 14
