Originally Posted by Daox
Here is another shot of where the charcoal canister should be. The rubber hose just goes right down where the can should be as if to bypass it. Perhaps it was deleted? Any negatives from not having this? Should I be looking to pick one up somewhere? I understand what it does, I just don't know how not having one would effect things. I'd imagine you just burn the gas fumes as soon as you start up.
i looked up the canister
Evaporative Emission Canister Replacement
Removal Procedure
1. Remove the fuel tank from the vehicle. Refer to Fuel Tank Replacement.
... so if you really wanted to, you could probably roll around on the ground with a flashlight and find where shes hiding
