Old 10-08-2014, 03:47 PM   #17 (permalink)
bestclimb
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Originally Posted by CapriRacer View Post
Also, tire wear is somewhat tied to inflation pressure, with increasing inflation pressure causing more wear in the center of the tread. Again, this is not well documented - in fact hardly documented at all. All we seem to have is those ubiquitous anecdotes..
My understanding is that bias tires had a significant center/edge wear vs pressure effect, but that radial tires have a much reduced correlation. My own measurements have borne this out (tread depth measured at 45psi which is 4 psi over sidewall shows linear wear outer center inner) a single tire is not much of a data set but does seem to fly in the face of the anecdote of over inflation causes center wear.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
