Here is the only current picture I could find on the side skirts.
I will make some more detailed ones tomorrow.
I removed the lower "rubber" trim piece from the car first. The skirt is actually attached to the side of the frame for the belly pan, which comes out flush with the bottom of the car. I made a top piece from thin sheet metal that attaches to the top of the skirt and angles up to "fill the gap" between the skirt and door sill. The skirt is 6 inches wide and is about 5 inches from the ground.
I will get a close up picture of the Kammback also. It is made from carbon fiber.
This car belongs to my brother, so he will be making all decisions about the "show" part of this project
